CNC-STEP
1805
CNC-STEP
1805
Replacement carbon brushes for milling motors Suhner and AMB (Kress)
MarketingCNC-STEP GmbH & Co. KG on April 1, 2021 at 8:30 AM
Depending on the milling motor's maintenance and use, you must replace the carbon brushes after a specific running time. It is advisable to replace both wear brushes directly, as wear occurs typically evenly.
We offer the carbon brushes for Suhner or AMB milling spindles in a set of 2. It's always advisable to have a spare pair in stock if the milling motor stops unexpectedly and working in is only possible after changing the carbon brushes.
We offer the replacement carbon brushes for AMB and Suhner on the milling motors' respective model pages on our accessories website.
The set for the AMB motor consists of one carbon without and one carbon with a switch-off device. For this, the carbon brushes are compatible with all our offered milling motors. The replacement carbon with red cable insulation has this shut-off element, which immediately switches off the engine in the event of wear, making carbon replacement unavoidable.
There are two identical carbon brushes for each of the Suhner models, but each model requires matching carbon brushes here, as these differ in size depending on the power of the milling spindles.
