CNC-STEP
1805
CNC-STEP
1805
May it be a wood milling cutter?
MarketingCNC-STEP GmbH & Co. KG on October 21, 2021 at 3:45 PM
This solid carbide wood milling cutter bit is very popular for machining plywood in model and guitar making.
The three-flute cutter with a straight flute gives a clean surface and a flawless routing groove at the bottom.
We stock cutters with cutting diameters from 1mm to 3mm.
