You are certainly already familiar with our 3D finder for determining workpiece zero points or the hole centre.
From now on, you will also find the corresponding replacement styli in two different versions in our CNC assortment.
The 25 mm long stylus has a ruby tip with a diameter of 2 mm, whereas the 22 mm long stylus has a ball tip with a diameter of 1 mm.
We bring precision to the point.
1805
FollowersReplacement stylus for 3D-finder
01Jul. 2021
MarketingCNC-STEP GmbH & Co. KG on July 1, 2021 at 3:30 PM
