CNC-STEP
1805
CNC-STEP
1805
Everything is turning!
MarketingCNC-STEP GmbH & Co. KG on July 31, 2018 at 12:30 PM
With our rotary axis RounDINO 120, you can expand your current 3-axis CNC milling machine with a fourth axis.
For example, you can engrave text or photos on round workpieces or simply mill rounds and realize 360 ° milling work.
This high-quality and extremely precise axle with worm gear is also suitable for milling metal. Thus, you have the opportunity to perform 3D work on almost all materials.
The RounDINO 120 rotary axis can also be used as a rotary table, as it can be installed by its mounting holes, both horizontally and vertically.
  • horizontal height: 70 mm
  • vertical height: 145 mm
  • weight: 3.9 kg
See further information about the product and applications.
