CNC-STEP
1805
CNC-STEP
1805
Would you like some wood milling cutter?
MarketingCNC-STEP GmbH & Co. KG on January 20, 2022 at 4:45 PM
This solid carbide wood milling cutter is very popular for milling work in plywood in model making and guitar production.
The three-flute cutter with a straight flute gives a clean surface and a flawless milling groove at the bottom.
We stock router bits with cutting edge diameters from 1mm to 3mm.
