586,389 active members*
3,196 visitors online*
Login Register
EMUGE-FRANKEN
News
2022-08-04 Double feed with the same axial force - the EMUGE Punch Drill
EMUGE offers a new tool to reduce main machining times: the EMUGE Punch Drill. Time savings of 50 % and more can be achieved with this drill - with reduced or the same axial force. Go to press info
2021-12-07 Larger dimensions for high-strength steels
Tapping of high-strength steels is increasingly in demand for larger diameters. EMUGE therefore provides additional, larger dimensions in the Rekord HCut carbide tap range. Go to press info
2020-04-06 100 Years of innovation, precision and proximity
In Lauf an der Pegnitz in Middle Franconia, Richard Glimpel laid the foundation stone for the family business EMUGE-FRANKEN 100 years ago. Always focused on innovative solutions to improve productivity in the machining industry, a group of companies with 1900 employees at 52 locations worldwide developed over the course of a century. Go to press info
2019-12-06 More diversity for milling small threads
The ZGF-S-CUT circular thread milling cutters from EMUGE are designed for machining difficult-to-cut materials such as Inconel or titanium. A new addition is the 3 x D length for milling deeper internal threads. Go to press info
2019-10-11 Coating against thermal shock
A new ALCR coating has been added to the proven FRANKEN Multi-Cut geometry. The milling cutters, which are more resistant to thermal shock, achieve a significantly longer tool life in high performance roughing. Go to press info
2019-10-02 Simple readout of the application data
The collet holder EMUGE Speedsynchro® Modular/ NFC now has as standard an NFC module which stores the application data. All important information is available by simply readout via a smartphone. Go to press info
2019-09-28 Flexibility for large threads
EMUGE's circular thread milling bodies with exchangeable face insert are offered with additional diameters and a second, longer version for even greater flexibility when milling threads from 12 mm in diameter. Go to press info
2019-09-27 Insert with circle segment technology
FRANKEN is expanding its range of circle segment end mills and offers this special technology now also as an insert. Go to press info
2019-09-20 Quick tool change at the touch of a button
The tap holder EMUGE Softsynchro® SnapLock allows a quick and keyless change of the threading tool directly in the machining centre without removing the holder. Ideal for limited magazine space and frequent tool changes. Go to press info
2019-09-19 For universal use in stainless steels
The FRANKEN TiNox-Cut milling cutters are extended with the type series "Base". As a TiNox-Cut entry-level line, it is aimed for universal milling applications in stainless and acid-resistant steels. Go to press info
2019-09-18 Quicker tapping of small diameters
Tools from M 1 to M 2.5 are now available for the EMUGE Punch Tap thread technology. This allows enormous time savings even for small threads. Go to press info
2019-09-17 Collaboration in Hybrid Additive Manufacturing
EMUGE-FRANKEN and the MATSUURA MACHINERY CORPORATION announced at the EMO their collaboration for tooling solutions in hybrid additive manufacturing. Go to press info
2019-09-16 New Taptor® technology for the production of internal threads
EMUGE Taptor® is a new technology for the production of internal threads developed together by EMUGE and AUDI AG. The threading tool combines a twist drill with a tap and leads to a significant saving in machining time. Go to press info
2018-11-12 World's first standard end mill program for Hybrid Additive Manufacturing
FRANKEN introduces the world's first standard end mill program for hybrid additive manufacturing, which enables milling operations during the building process of additive construction of a component geometry. Go to press info
2018-10-31 Easy manufacturing and inspection of threads with specified starting position
EMUGE PoCoSys comprises a tool system for easier manufacturing and inspection of threads with specified starting position. All system components have been matched to each other - from the tool holder and threading tools to the setting gauges and testing equipment. Go to press info
2018-10-30 Longer tool life and process reliability in thread forming operations
The EMUGE cold-forming tap InnoForm Steel-M sets new standards with its innovative geometry and coating. Go to press info
2017-10-02 Contour-accurate finishing in turbine production
The new geometry of the FRANKEN Pagode form end mill allows for a higher feed and a smoother run compared to previous form end mill with pine-tree profile. Go to press info
2017-10-02 The specialists for Impellers and Turbine Blades
FRANKEN, the pioneer in circle segment end mills, completes the milling program for the machining of impeller and turbine blades with new roughing and finishing tools with internal cooling. Go to press info
2017-10-02 Tool Holder with adjustable projection length
Thanks to its adjustable projection length, the EMUGE Softsynchro® Xtension tap holder is aimed at the production of low-lying threads in components. The user benefits from an increased flexibility without compromising rigidity. Go to press info
2017-09-22 Quick change for taps
The tap holder EMUGE Softsynchro® QuickLock allows for a quick change of the threading tool in the machining center without having to remove the tool holder. The user benefits from a higher flexibility and time savings. Go to press info
2017-09-22 Addition to the Punch Tap Family
The helical cold-forming tap EMUGE Punch Tap is now available in additional variants. New thread sizes were added for thread production in cast and wrought aluminium alloys. Go to press info
2016-06-28 Circle Segment End Mills of the product line FRANKEN Expert
The special geometry of Circle Segment End Mills offers improved surface quality by simultaneous reduction of machining time. They focus on prefinishing and finishing operations on five-axis machining centres. Go to press info
2016-01-08 EMUGE Enorm-Z Taps made of HSSE-PM for long-chipping material
The EMUGE Z-series has been developed especially for machining on CNC-controlled machines. Their geometry is made for blind hole threads. The taps are offered in two coating versions, with or without internal coolant supply. Go to press info
2014-12-11 New Circular Thread Milling Cutters
EMUGE, manufacturer of thread cutting and clamping tools in the EMUGE-FRANKEN company group, extends its product program of Circular Thread Milling Cutters. The new products enable cutting of longer threads and of materials, which are difficult to machine... Go to press info
2014-12-04 HSS End Mills redefined
FRANKEN, manufacturer of milling tools in the EMUGE-FRANKEN company group, introduces new HSS End Mills for roughing and finishing. Combining improved HSS-materials with new, modified geometries and innovative coatings, the end mills optimize milling processes, reduce cycle times and open up new areas of application... Go to press info
2014-12-02 Shorter Cycle Times at Thread Production
With smaller thread diameters in particular, CNC machine tools often do not realize the programmed rpm due to the limited synchronous control. Then thread cutting tools are not operated with the ideal cutting speed which may have a negative impact on the cycle time and tool life of the threading tool... Go to press info
2014-11-24 Extended Product Range of Hydro-Expansion Clamping
EMUGE, manufacturer of thread cutting and clamping tools in the EMUGE-FRANKEN company group, extends its hydro-expansion clamping product range. This ensures the submission of the most suitable clamping solution to the customer comprising either mechanical or hydraulic clamping systems... Go to press info
2014-11-14 EMUGE Thread Depth Plug Gauge
EMUGE, manufacturer of thread cutting, gauging and clamping tools in the EMUGE-FRANKEN company group, introduces the new Thread Depth Plug Gauge with wireless data transfer. It offers significantly more freedom of movement at gauging working place or at the machine... Go to press info
2014-09-24 Punch Tap – the Revolution in Thread Production
EMUGE, manufacturer of thread cutting and clamping tools in the EMUGE-FRANKEN company group, presented at AMB fair in Germany an innovative thread technology. The Punch Tap technology shortens significantly the cycle times of thread production while reducing energy consumption... Go to press info
2014-03-11 Video Franken Turbine
A new video clip is at our Youtube-Channel available. It shows the advantages of the FRANKEN Turbine end mill. Please have a look at our channel! Go to press info
2014-02-10 New List Prices effective from March 1st 2014
We have been providing high-quality precision tools to our customers for many years and this way have contributed to a process-reliable and economical production... Go to press info
2014-01-27 FRANKEN Turbine in press
The German trade-magazine "Fertigung" published an interview about our new productline FRANKEN Turbine in its december issue... Go to press info
2014-01-20 New video clip EMUGE Gigant Modular Sprinter
A new video clip is at our Youtube-Channel available. It shows the advantages of the modular construction of Circular Thread Milling Bodies. Please have a look at it! Go to press info
2014-01-10 EMUGE-FRANKEN shows in 2014
Also in 2014 we will exhibit our products at numerous domestic or foreign trade shows, even some with live demonstration. Go to press info
2013-11-29 EMUGE-FRANKEN at Euromold 2013
From 3rdto 6th of December we will present tools of our product line FRANKEN under the theme “Efficiency through systems” at the EUROMOLD fair... Go to press info
2013-10-28 Technical Article: The run-out improver
A new EMUGE clamping principle tolerating relatively large deviations of boreholes, was presented for the first time at the EMO... Go to press info
2013-10-14 New product: Twin Taper clamping system
Based on proven clamping systems SP and SZ, EMUGE has developed the new clamping system ST. It aims on clamping at workpiece bore holes, which are slightly unprecise... Go to press info
2013-09-12 Modular circular thread milling bodies for shorter machining time
EMUGE extends its GIGANT thread milling range with a modular version, which enables the connection up to three circular thread milling bodies. Depending on application, saving of machining time is possible... Go to press info
